When using a tag, revit selects literally any item you are hovering near; This slows down the computer and the makes tagging a nightmare. There needs to be a setting such that if you are tagging ceilings, only ceilings are selectable for that tag. The same with MEP fab duct tags, room tags, etc. Having revit cycle through every visible item is truly a waste of computer resources and time.
