Assemblies need to behave better, sort of like a family, but built inside the project (not to be confused with in-place components, no).
My idea is for assemblies to start working more independently from the model:
- Add the ability for them to be mirrored, copied and altered, with those alterations affecting the copies instead of creating new assembly types.
- Enable the use of commands such as trim, extend, etc inside the assembly editor
- Make the assembly views INDEPENDENT from the model, it's really annoying when you have all the views and everything set up in the sheets, and you realize you have to shift the assembly a little to the left, and that messes up all your perfectly aligned work. OR even worse, when that first assembly copy, the one the views are dependent on, has to go.
If you ever worked with assemblies, you know what I'm talking about. Give this idea a thumbs up and *hopefully* Autodesk will hear about it.
