cancelar
Mostrando los resultados de
Quiere decir:
Make all font types work correctly on dimensions
I use the font Cambria on my drawings and I've noticed this font in many situations does not work well when applied to dimensions. For example, when a dimension is vertical, if I have manually added text in the "Below" line of the dimension's text, the line goes down an extra text line away from the dimension string when I print it, even though when I view it in Revit it looks fine (except when I zoom in). See the screen shots numbers 1 and 2, attached. Also, when a dimension is diagonal with Cambria, and possibly other font types as well, the value of the dimension, normally above the dimension line, now moves below it--even though when the mouse hovers over the dimension, Revit has an empty box where the text should be. See screen shot #3, attached. If font types in dimensions would be fixed so they appear normally like Arial appears in dimensions, this would make my drawings look even better, which I would greatly appreciate.
2 Comentarios
lionel.kai
This sounds more like a bug than something that should be an "idea"/feature request... but then again I know I'm told to post ridiculous things here by the support staff... did you try submitting a support request first?
I wound up submitting Case Number: 15654033 for bug from a related idea:
Diagonal Text With Opaque - Bounding Box Fails
and I mentioned this problem (at the end) since it might be related:
https://autode.sk/2MYKjcu
Redrunner92
Hello @lionel.kai , yes this is certainly a bug. (I'm using my personal account here to respond, I didn't mean to use my company's account when I originally posted). I'm still learning which boards are for which posts.
Anyway, thank you for recording your bug video and showing the extra bit on the end about non-Arial texts' behaviors. Let's hope Autodesk will address this bug now that you and I and others have called attention to it.
Enviar idea
