Currently, you can set column widths in schedules by way of the resize option on the toolbar in the schedule editor, but you can't lock the width.
In Revit 2023, if you use the "filter by sheet option", the column widths keep resizing themselves on their own accord. Have a look at the short video and can see the window schedules columns resizing themselves when a wall was added to the project, which has absolutely nothing to do with any window. You later end up going to a sheet view of your schedule only to find your schedule has expanded across the page to where it shouldn't be!
So the idea here is that we can actually set and then lock in the widths so this can no longer happen.
Personally, I think we should be able to do this from the sheet view of the schedule with little locks that can be clicked on and off.
