cancelar
Mostrando los resultados de
Quiere decir:
Line Style for <invisible> lines
There's no Line Style for <invisible> lines. For this type of lines, color and line type are no issue, but the weight IS. Especially when used in a Masking Region where <invisible> lines frequently need to obscure what's beneath. And NO, the Line Work tool cannot be used in those situations.
4 Comentarios
lionel.kai
Could you provide an example? If you only need this for Masking Regions, you can just create a white Line Style at the desired weight...
Simon_Weel
@Anonymous: Indeed, needed when creating masking regions. But things can be SO easy - as you just pointed out.... Never crossed my mind to use a white line.......
wr.marshall
You could use a white line style as mentioned. However this can cause issues in other views. EXAMPLE: I created a window family with a RECTANGULAR pitch adjustable sill. I then placed a triangle (concrete back end fill) between the rectangular sill and the wall. Using the white line style hid this in plan, however when I went to the section view the triangle required a outline but was just showing the hatch pattern. I could probably draw a line to close up the triangle. I think a better idea would be able to select an individual line in a given view and either change its line style or set to <invisible> as the wish. A good example of this can be seen in an Inventor drawing where you can override an individual line to hide it, removing it from the view.
wr.marshall
Enviar idea
