Jump to selection in project browser
Give us a context menu entry inside the project browser that will "jump to selection". This may be greyed out if the selection makes this impossible, ie. more than one familiy is selected or something that does not show in the browser.
3 Comments
jkidder
This would be very handy for views - I'll get to a view by references, but then want to copy it or similar and it takes awhile to find.
Maltezc
Hi all,
I created a tool that might help you with your "jump to selection" issue for views
It helps you jump around Revit views pretty quickly and also remembers your last 20 views you were in.
It beats the hell out of having to scroll through the project browser.
Hope this helps.
https://apps.autodesk.com/RVT/en/Detail/Index?id=210622567483130564&appLang=en&os=Win64
Disappointed
I would go as far as considering this implemented, unfortunately it is not mentioned into which version: https://www.autodeskproductresearch.com/hub/posts/post-25692765?utm_campaign=newsletter&utm_content=...
