It is suggested that revit can choose based on the measurement point when measuring the coordinate point data of the road.
In fact, the coordinate data measured in the field is tens or even hundreds of kilometers, while revit cannot support almost infinite range as CAD, and often requires data conversion when importing data to generate terrain. If only you can directly convert the origin according to the data of the measured point during the import. For example, the measurement data X: 10000.000, Y: 20000.000, Z: 500.000, set the measurement point to X: 9999.000, Y: 19999.000, Z: 499.000. After import, this point appears at the points X: 1.000, Y: 1.000 and Z: 1.000.
