Interference check: add level/base constraint parameter to report
Currently when running an Interference Check you only get the element's name, category and ID.
This makes it difficult/tedious to resolve each clash one-by one, as you can't really work per level. Or even if you want to distribute the work among modellers, you can't assign a level to a person, so people are all over the building trying to solve clashes.
Adding a level/base constraint parameter would greatly improve this tool, as the exported report can then also be filtered by level. Thus allowing us to systematically resolve the clashes, instead of running all over the place.
