Currently, it looks like it is only possible to increment the first list within a text note. If, for some reason, you wanted to add a second list within the text note that does not start at the beginning, then you could not. In my particular case, I was modifying text that had been formatted in AutoCAD and I had to do manual multilevel list formatting due to the limitations of the Revit text editor. I wanted the text note to start at K. After the custom formatting, I wanted to be able to start a normal list at L. Apparently this is not possible in 2018. To get everything to look right I will need to start a new text note.
