cancelar
Mostrando los resultados de
Quiere decir:
Improving the spare circuit feature behavior
In Revit MEP panel schedules, spares can only be added for a single pole circuit. The tool should allow a user to add 2 and 3 pole circuits, and have the same appearance/behavior in the panel schedule as a connected 2 or 3 pole device, where the circuit breaker rating is only inlcuded on the top row.
A screencast displaying the issue is included.
2 Comentarios
Martin__Schmid
El estado se ha cambiado a: Gathering Support
Hi David-- thanks for the suggestion...
While it's true, you can only create a 1 pole spare.. you can change the poles from 1 to 3 after it is created.
I'll mark this as Implemented... unless I'm missing something in this request?
https://autode.sk/2B3AB46
Martin__Schmid
Thanks for those of you that voted on this... to close the loop on this, the issue that @dbutts7 has is that he does not show the number of poles on the panel schedule, so there is no place for this value to be modified easily from within the panel schedule view.
Enviar idea
