Improve the French translation of your software.
In the French version of Revit, many terms used in Revit, seem to come from an automatic translation. So some of them do not mean anything or are inapropriate. Example :
For Ducts:
English Revit : Velocity pressure
French Revit : Pression de vitesse (No sense)
French : Pression dynamique
For Ducts or Pipes
English Revit: Section
French Revit : Coupe (No sense)
French : Tronçon
For Ducts or Pipes or Cable Tray
English Revit: Top Elevation / Bottom Elevation
French Revit : Elevation du Haut / Elevation du Bas (Not usual)
French : Arase supérieure / Arase inférieure
For Pipes
English Revit: Inverted Elevation
French Revit : Inverser l'élévation (No sense)
French : Elevation Inverse (Arase inférieure ?)
For Ducts or Pipes
English Revit: Endcap
French Revit : Couronne (No sense)
French : Extrémité (There is no judicious translation, but "couronne" is not at all appropriate)
HVAC Units:
English Revit: Cross Section
French Revit : Coupe (Still?)
French : Section or Section de passage
Etc...
Bye
11 Comments
For Ducts or Pipes
Je propose "Bouchon" ou terminaison.
dgorsman
Are there regional differences to consider, such as "French" French vs. Quebec/Canadian French?
Thierry.A
@Jacquesrigal3467: Yes, "Bouchon" for "EndCap" is so obvious that I did not think about it 🙂
@dgorsman: If a Quebecker or a Belgian or a Swiss, or any other Francophone, goes through there... 😉
Hello t.archambault,
I search other traduction.
It's very important to consult other francophone for that.
Regards.
HVAC Units:
section de croisement  ou section transversale.
Hello Thierry,
Do an email to the francophone Expert Elite.
You'll get returns more important in response to your questions.
Regards.
sasha.crotty
Thanks for submitting your idea. Your suggestions for improvement were reviewed by our localization team and a number of them were adopted into the product. You should be able see some of these changes reflected in Revit 2018.1 which was released last week. A few others may make their way into future content updates.
fruity101079
4 years later, and nothing has been done, all examples quoted are still there.
For new users and beginners, it's incomprehensible...
ps:
For Pipes
French : "Fil d'eau" me semble pas mal, même si on ne l'utilise généralement qu'en gravitaire.
seb.vcf
please, it would make more sense this translation :
For Beams :
English Revit : Structural Framing
French Revit : Ossature
French : Poutres
For Floors:
English Revit : Floors
French Revit : Sols (mistranslation, "Sols" means ground in french)
French : Dalles
seb.vcf
French Revit : Direction secondaire
French : Direction mineure supérieure2023-01-02_15h43_17.png
fruity101079
In french, we don't say "nouveau famille" but "nouvelle famille".
And in the plural, we grant: nouveaux modèles, nouvelles familles.
Or, you have to remove the S at the end of the two words, it may be useless because you open only one file.
