Improve Pressure Loss Method for duct fittings in Revit
1. In Loss Method of duct fittings Properties, for the options "Specific coefficient" and "Specific Loss", it works for elbow, transition fittings(two connector fittings), and currently its limitation for Tee/Tap or Cross. so we have to use ASHRAE Table for these fittings.
Please add the option to specify the Loss Method as User Defined and apply the value to the Pressure Drop parameter, like when specific a coefficient, input both Main and Branch coefficient in Properties.
2. Currently when working with ASHRAE Table for different sizes, often shows”No ASHRAE table is applicable to the selected object" or incorrect table in Loss Method Settings dialog box.
For example, reading the table ER5-3 from ASHRAE standard, the table is only valid when Ab/Ac=0.5. But in engineering design working with ASHRAE Table,when Ab/Ac ≠0.5, we also refer to the value in table ER5-3.  Ab/Ac=0.5 is a test environment in ASHRAE, should not be the necessary condition.
So please remove unnecessary conditions when looking for ASHRAE  tables in Revit.
5 Comments
Jeff.Shi2LF44
The following link features the similar path I went through, it brought up the problem:
https://forums.autodesk.com/t5/revit-mep-forum/pressure-loss-through-tap-always-zero/td-p/4952246
Some users expressed a bit of frustration in the link above, then a solution came out later in Revit 2017. The solution supposes to work by leading us to built-in ASHRAE mapping, and the case status changed to “Implemented”.
https://forums.autodesk.com/t5/revit-ideas/pressure-loss-through-tap-always-zero/idi-p/8897291
But the ASHRAE mapping in Revit follows a very very strange way, it tends to break easily and does not give any informative prompt about what went wrong.
https://forums.autodesk.com/t5/revit-mep-forum/working-with-ashrae-tables/m-p/7562417
Iev60047
This feature would actually make the duct fitting database in Revit useful!
kenny.choi
Agree
Austin_PlattsQTYGV
Community Visitor
Agree, currently you can't even use Revit for static pressure calcs because it can never recognize the ASHRAE data base table. It is crazy Autodesk still hasn't fixed this duct fitting issue. Static pressure calculations are very time consuming, and fixing this issue would probably revolutionize how the next generation of engineers do static pressure calcs.
J_brechtezende
Community Visitor
Das Problem besteht mittlerweile seit über 15 Jahren und ist in unzähligen Kommentaren und Foren dokumentiert. Leider scheint Autodesk keinerlei Interesse zu haben, diese wichtig Basisfunktion ans laufen zu bringen. Es würde müsste den Nutzern nur die Möglichkeit gegeben werden, die hinterlegten Ashrae Tabellen zu modifizieren und zu bearbeiteten, so dass sie für alle Formteile funktioniert. Es kommt der Verdacht auf, dass hier Drittanbieter, die entsprechende Tools anbieten geschützt werden. Diese Tools wären alle mit einem Schlag überflüssig und die Berechnungen würden sogar live erfolgen und müssten nicht wie bei den externen Tools jeweils gestartet werden. Schade Autodesk. Ihr habt es in 15 Jahren nicht geschafft eine Basisfunktion für die Kanalnetzberechnung ans laufen zu bringen.
