cancelar
Mostrando los resultados de
Quiere decir:
import DWG's control
When I import a DWG from a third party (witch I often have to do) and if the import drawing contains (solid) hatches and 2D solids I get a big black blob in that section. Then I must open the DWG, remove all the hatches en re-import. It would be great if I could toggle an import function with or without
hatch.
To be short more DWG import control.
1 Comentario
Renato.94
Sometimes we need to import logos from our clients in dwg, but for some reason revit brings some of these elements to layers that are not editable (for example a region filled in with this) it would be a good idea to be able to assign independent layers to these filled sections or layers. each logo dwg imported
Enviar idea
