IFC export - split Pipes and Ducts by Level
Usually vertical ducts and pipes are modeled over many levels. It would by nice to have a split by level tool, as a command in Revit and/or when exporting to IFC.
7 Comments
Yes please
ab_adsk
just received another request from a customer for ability to split pipes while exporting IFC. It really would make sense, it works for the ducts already and adding pipes would be the next logical step to do
Best would be if it could be done in revit. Both for pipes and ducts. And also for revit to change the reference level accordingly. As it is now it is just annoyingly inconvinient
fabian.brunner
Good idea, hast to be added for cabletrays and conduit aswell.
Is this added? or is this something you can do?
Hauk-Morten
While we are waiting for a native Revit solution for this, NTI Tools has a plugin with a tool that does this already 🙂
j.uschakow
In addition to the splitting of pipes, cable trays, and conduits, it would also be beneficial if elements whose reference level is not a building story level could be divided by story during export. The assignment logic should be analogous to that of horizontally running elements, which are assigned to the next building story level below.
