Hide next warnings for x amount of time
An option to hide warnings for x amount of time.
While you're working, various warnings of varying categories or importance appear.
Some are just for informational purposes, others force you to choose between "Accept", "Cancel," "Ungroup," etc.
Sometimes you're working quickly and don't care, or you know you'll always respond the same way to these warnings.
It would be nice to have an option to "respond the same way for the next x minutes."
Similar to the "do the same for all items" option that Windows gives you, but with a time limit, or at least until you close and reopen Revit
Una opción para ocultar las advertencias durante x tiempo.
Mientras trabajas, aparecen varias advertencias de distintas categorías o importancia.
Algunas son solo informativas, otras te obligan a elegir entre "Aceptar", "Cancelar", "Desagrupar", etc.
A veces trabajas rápido y no te importa, o sabes que siempre responderás de la misma manera a estas advertencias.
Sería bueno tener una opción para "responder de la misma manera durante los próximos x minutos".
Similar a la opción "hacer lo mismo con todos los elementos" que te da windows, pero con un límite de tiempo, o al menos hasta que cierres y vuelvas a abrir Revit
1 Comment
CEdwardsUN5MX
Yep. being babysat by Revit all the time, and forced to confirm that yes I want to do the thing I want to do, gets pretty darned annoying when it is happening possibly dozens of times an hour.
The default in the case of something like 'X Object will unjoin from Y object' is also always to cancel the action, which is pretty annoying when numerous messages are also warnings of no consequence. So I am forced to engage with them, to get what I want done, to avoid cancelling the action and having to do it again.
If that behaviour could be under some user control, it would speed up working, and remove one of the very many annoyances this software generates consistently throughout the day, which provides little benefit for more experienced users.
