Hide if not in the core
I would like to have an option to hide everything that is out of the core of an element (for example for walls). As a structural engineer I do not want to see the finish part of the wall, since there's already a difference between core and other parts (in the type of the element) why it is not possible to use this property and turn off everything that is not a part of the core? Maybe in the view settings.
Thank you in advance.
5 Comments
@DarioCulap  good idea..Right now if you want to isolate structural part of the walls you make of them parts and then per filter you could isolate just structural part.
Use a filter.
Pshupe
How would you use a filter to turn off the non-core elements inside a wall type?  Thanks.
Regards Peter.
I made a mistake, I don`t think it is possible to assign a parameter that can be filtered in the material of a wall.
I have the same problem as DarioCulap.
Does the above mean that there is not a way to use a filter to exclude anything is non-core elements within walls?
Forma Design Contest
Technology Administrators
