Hide if not in the core
I would like to have an option to hide everything that is out of the core of an element (for example for walls). As a structural engineer I do not want to see the finish part of the wall, since there's already a difference between core and other parts (in the type of the element) why it is not possible to use this property and turn off everything that is not a part of the core? Maybe in the view settings.
Thank you in advance.
6 Comments
@DarioCulap  good idea..Right now if you want to isolate structural part of the walls you make of them parts and then per filter you could isolate just structural part.
Use a filter.
Pshupe
How would you use a filter to turn off the non-core elements inside a wall type?  Thanks.
Regards Peter.
I made a mistake, I don`t think it is possible to assign a parameter that can be filtered in the material of a wall.
I have the same problem as DarioCulap.
Does the above mean that there is not a way to use a filter to exclude anything is non-core elements within walls?
kimberly.fuhrman
Status changed to: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
To follow the progress of features in development, please see the Revit Public Roadmap and join the Revit Preview Release to participate in feature testing. (Note that Accepted Ideas may not be immediately available.)
The Factory
Forma Design Contest
Technology Administrators
