Does anyone notice one hidden line in Graphical column schedule for rotated columns even if we set all hidden lines as none in properties.
If we place one Structural Round concrete column in plan and then rotate that column in plan (any degree other than orthogonal) such that there is no change in any appearance except its reference planes since it is round column. Now if we place any floor in that project, a hidden line appears in Graphical column schedule for that rotated column even if we set all hidden lines as none in properties. Now this hidden line will not disappear even after we delete that floor .
This should not happen since this is a round column.
Only solution I found is overriding that hidden line using linework tool using invisible line.
Does anybody know any other option or the category/line this hidden line comes under so that this can be changed globally.
This is coming for all projects with rotated columns for some needed purpose (Obviously there will be floors and other structural elements that makes the appearance of this hidden line) .
