Halftone filtering
Halftone filtering
When applying filters, the halftone setting only has a value of "YES", but I would like you to set "YES / NO" as a value. The graphics override applied by category and the graphics override applied by the filter are usually drawn with priority on the filter,
Halftone has no NO value, so if you set it to YES on the category side, the value will not be overwritten even if you set it to NO (unchecked) on the filter side.
It is displayed in halftone. We would like to control to release the halftone of the case when the double condition is met. (Matches the first condition: Halftone is applied,
Matches the second condition: I want to perform the operation of releasing halftone.) For example, all objects in the exterior category are displayed in halftone, while objects in the exterior category created in place display halftone.
For example, when you want to cancel and display it.
1 Comment
ChrisGamble
I understand exactly what you mean. Seems like a unrecognized defect. Even when I was about to apply a filter to set my specific family to not be halftone with the rest because its category is checked halftone in model categories,  I had a feeling what I was about to do wasn't going to work, and it didn't...
