cancelar
Mostrando los resultados de
Quiere decir:
Global Parameters for Extension Distance
Allow Global Parameters to be used for Base and Top Extension Distance Parameters in Walls.
Commonly the sheathing layer/s on metal frame walls will oversail the structural slab on which the metal framing is fixed. We often use the Base or Top Extension Distance parameters in Revit to control the outer layer and it would be useful if these could be linked to a Global Parameter for consistency and ease of updating should the structural slab thickness change.
1 Comentario
andy.kilby
Same goes for skirting in WoodFrame!
Enviar idea
