Add function to return discipline for a ParameterType similar to UI add parameter dialogue.
When all ParameterTypes are listed together many have the same name returned by LabelUtils.GetLabelFor(ParameterType) e.g.
HVACDensity = Density
PipingDensity = Density
HVACTemperature = Temperature
PipingTemperature = Temperature
ElectricalTemperature = Temperature
The above parameters will only be distinguishable in a custom UI if they are able to be divided into discipline.
Function similar to below should be available within API and maintained for new parameter types added.
Public Enum ParameterTypeDiscipline As Byte
Undefined = 0
Common = 1
Structural = 2
HVAC = 3
Electrical = 4
Piping = 5
Energy = 6
End Enum
Public Shared Function GetParameterTypeDiscipline(Val As ParameterType) As ParameterTypeDiscipline
Dim V As Byte = CByte(Val)
Dim D1 As Byte() = New Byte(14) {1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 19, 20, 159, 172, 222}
Dim D2 As Byte() = New Byte(40) {11, 12, 13, 14, 145, 146, 147, 148, 150, 151, 152, 153, _
154, 184, 185, 192, 193, 194, 195, 196, 197, 198, 199, 200, _
201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 223}
Dim D3 As Byte() = New Byte(28) {107, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 125, _
156, 158, 160, 161, 162, 163, 164, 165, 166, 167, 168, 170, 179, 180, 187, 188, 227}
Dim D4 As Byte() = New Byte(21) {15, 18, 119, 120, 121, 122, 123, 124, 134, 135, 169, 173, _
174, 175, 177, 178, 181, 182, 183, 186, 221, 229}
Dim D5 As Byte() = New Byte(16) {16, 136, 137, 138, 139, 140, 141, 142, 143, 144, 155, 171, 189, 224, 225, 226, 228}
Dim D6 As Byte() = New Byte(7) {108, 157, 190, 191, 217, 218, 219, 220}
If D1.Contains(V) Then
Return ParameterTypeDiscipline.Common
ElseIf D2.Contains(V) Then
Return ParameterTypeDiscipline.Structural
ElseIf D3.Contains(V) Then
Return ParameterTypeDiscipline.HVAC
ElseIf D4.Contains(V) Then
Return ParameterTypeDiscipline.Electrical
ElseIf D5.Contains(V) Then
Return ParameterTypeDiscipline.Piping
ElseIf D6.Contains(V) Then
Return ParameterTypeDiscipline.Energy
Else
Return ParameterTypeDiscipline.Undefined
End If
End Function
