cancelar
Mostrando los resultados de
Quiere decir:
Footing Schedule-thickness shared parameter
There is a previous post regarding how to work around the OTB rectangular footing family not scheduling the thickness.
This is a really easy fix for the next release of Revit. Change the existing parameter in the family to be shared.
Its been broken since I started using revit in RS4. Its never been fixed (as of Revit 2015). As such, the OTB family is never used.
5 minutes and any revit user on autodesks staff could fix it.
Cheers
9 Comentarios
cindy_wang
@SeanSpence, thanks for bringing this to my attention. I've filed a defect in the Revit development team's database and the team is reviewing the correct way of doing this.
pawelpiechnik
In response, this request has been addressed in the Revit 2017. Please check it out.
More information available here: Revit 2017 Help page
regards
Pawel Piechnik
SeanSpence
AWSOME!!!
I was starting to loose faith in the idea station.
Thank you @pawelpiechnik  on behalf of all structural Reviteers!
pawelpiechnik
El estado se ha cambiado a: Implemented
No aplicable
 @cindy_wang @pawelpiechnik
This is NOT fixed yet!  I have Revit 2017 and it is absolutely not default parameter.
No aplicable
Hi there! im just here to tell you im using revit 2020 and still does not have this. Says "Fundation Thickness" but appears blank when you schedule. Thanks
Tarek_K
El estado se ha cambiado a: Gathering Support
SeanSpence
@Tarek_K again, this has been implemented. why is it going back to gathering support?
Tarek_K
Enviar idea
