I think it would be immensely helpful to be able to use the slope arrows for a roof or floor structure and when one has created a floor structure (sandwich) with layer(s) indicated as being "variable" that the slope arrow applies only to that/those layers.
Therefore, we could model a roof with layers: metal deck, rigid insulation (5" height), tapered insulation (1/2" height, variable selected), membrane roofing. The minimum, then, that the variable layer would be is the 1/2" - per the stipulation in the construction of the roof - and then would slope with the arrows above that.
This would be even more helpful if one could add numerous arrows that the program could mathematically derive the angles, peaks, and valleys automatically based upon these arrow head and tail locations.
I understand that this could likely be more involved to program, but the usability of roofs and floors would increase significantly as opposed to the current workflow of trying to establish the point locations, offsets, etc. that we currently undertake.
Thank you.
