Floor and roof slope arrow for variable thickness material
I think it would be immensely helpful to be able to use the slope arrows for a roof or floor structure and when one has created a floor structure (sandwich) with layer(s) indicated as being "variable" that the slope arrow applies only to that/those layers.
Therefore, we could model a roof with layers: metal deck, rigid insulation (5" height), tapered insulation (1/2" height, variable selected), membrane roofing. The minimum, then, that the variable layer would be is the 1/2" - per the stipulation in the construction of the roof - and then would slope with the arrows above that.
This would be even more helpful if one could add numerous arrows that the program could mathematically derive the angles, peaks, and valleys automatically based upon these arrow head and tail locations.
I understand that this could likely be more involved to program, but the usability of roofs and floors would increase significantly as opposed to the current workflow of trying to establish the point locations, offsets, etc. that we currently undertake.
Thank you.
20 Comments
coreyb
The only way to do this currently is to modify the sub elements or a roof/floor. Or to create 2 separate elements and join them to mimic a sloped roof/floor.
Also, when a roof/floor sub elements are modified the interior lines are not correct with the slope.
JADAstudio
This would indeed be very helpful. Modifying sub-elements of a roof is imprecise and leads to confusing geometry (automatic break lines) for all but the most simple roof shapes. Additionally, the workflow of modifying sub-elements is not aligned with how designers conceive of low-slope tapered insulation roofs nor how these roofs are actually installed. There should be some way to specify a slope (e.g. 1/4"-1'-0" via a slope arrow) and have the "variable thickness" layer grow to accommodate... something like an instance parameter for roofs sloped via slope arrow(s) that is equivalent to "flat bottom".
Account.02
i'm in according with "baumbach", sub-elements aren't usefuull if i have a complex shape.
It'a necessary that variable layer works also with slope arrow!!!
It's time that Autodesk begin to develope Revit!!!!
In this forum there are a lot of suggestions but, Autodesk ignore all of them!!
Autodesk needs to implement the possibility of creating floors with slope arrows and variable thickness. This would greatly (!) enhance the workflow and versatility for creating sloped floors in Revit. Now, if you create a sloped floor with a variable thickness you need to modify the sub elements of the floor to get the right slope. If you need to modify the boundary of the floor after you have modified your sub elements then you need to re-modify the sub-elements again! Unacceptable!
The issue has been noted before in other threads on the forum.
Tags (4)
matb
Agreed it would be useful.
To do the same with a complex roof shape, Ive drawn a reference plane through in section then used the shape editing tools to pull the various levels of the roof to match.
bit of a ball ache but it works well.
XXalessio.amodioXX
It would be nice to be able to model a sloped roof (Slope arrow - Define slope) with a variable layer.
amelie8RZBG
Agreed! It would also help a LOT for the chaotic slope lines that result from modifying sub-elements on a non-rectangular roof. This would be such a simple and valuable change! As it is we're forced to use linework tools to hide unwanted ridges. It's not "smart" at all - very frustrating.
justinpelliott
Agreed.
Slope arrows made short work of a roof with an irregular boundary, but the layer set to variable in the assembly did not vary, it maintained it's thickness. 😑
rookio
Upvoted this one. Ability to define the slope of a variable layer would be a HUGE benefit to workflow of complex roofs.
Please implement this idea!
c'mon autodesk sort out the basics
AMalschaert
Community Visitor
Bizarrely I have a project open now where two roofs with a complex outline and a variable thickness layer. They both have the top controlled by a slope arrow and are both of the same type. One of them has a flat bottom side and the other doesn't. It seems to me this problem is already half fixed. Joking asside. I can' t figure out why these two roofs behave differently.
tylerVD3L4
I would really like to be able to do this.
steiner
Allow variable heigts of slabs witSlab with variable heigt per slope arrow_220804.jpgh slope arrows
Tags (3)
steiner
04.08.2022 18:47:
Added sketch for better unterstanding.
steiner
Allow variable heigts of slabs with slope arrowsSlab with variable heigt per slope arrow_#2_220804.jpg
Tags (4)
steiner
@kimberly_fuhrman-jones could merge my post and the votes into the following one:
https://forums.autodesk.com/t5/revit-ideas/variable-slab-layer-with-slope-arrow/idi-p/11340478
Made a double post by mistake. Thanks in advance.
Greetings
ssullivan_dARC
Please provide an option for creating a variable thickness roof/floor using slope arrows and slope defining edges. Currently, it is only possible utilize a roof/floor with a material thickness set to variable if you Modify Sub-Elements.
Tags (5)
ks2_wmb
The orange shape is an in-place extrusion, and the top of the extrusion matches the slope that I want for the top of the roof.
I'm using the align tool to control the sub-element points, aligning them vertically to my in-place extrusion.  All my points are co-planar (because the extrusion top is planar), but Revit somehow can't tell that the geometry is planar and refuses to clean up the mesh lines.
Why isn't there a better way to do this?
(this is taken from a real project in our office, but these two elements are temporarily isolated this view)
mhenderson
Yep. Why are you making humans do the math for a computer?  This should work for both slope arrow or "edge defines slope" It's just a basic need for any building with a low-slope roof or slopes around floor drains that every nearly project would use.  As it is now, If I have a low-slope roof assembly I basically have to split it into every piece of the pie and cut vertical opening in it around obstructions to avoid having to do the math for to determine the elevation at every vertex.  Why do we have to wait 20 years for this...just make the variable toggle actually work in all cases, then I could make one roof element and let the machine do the math...It would be like the inverse of a multi hipped steep slope roof.  I cannot think of an instance where I would want the use of a slope arrow to override the variable thickness toggle...if you want a uniform assembly thickness, there's no reason to use the toggle  (Now I have Mitch Hedberg's "receipt for a donut" bit going through my mind).
calexander_PCO
"Receipt for a donut"... classic!
