cancelar
Mostrando los resultados de
Quiere decir:
Flattened curved elevations / sections
When elevated, curved surfaces do not show the full length of the wall.  Moreover, graphics become skewed.  We would like to be able to wrap an elevation tight to the curvature of the wall so that the elevation appears to be a flattened out curve.  You could do this by offsetting a line from the curved wall and picking that line as the elevation path.
46 Comentarios
Dear all,
We are expecting the curved section in this image to be attached (reference from youtube)
is there any script or other method? please suggest
bjoern_teutriene
@rajan_kaliyugavaratharajan
There is an App for Revit called Bridge + Infrastructure Modeler which can be used to create unfolded sections by Revit command.
Have a look here for further information: https://docs.sofistik.com/2024/en/bridge_modeler/cmdref/shop_drawings/unfolded_section.html
aizaiwutuobang
在某些时候设计师希望通过对复杂的形体创建一个展开的立面视图来表达设计意图。例如从A到B 是一个由直线、圆曲线、样条曲线及缓和曲线组成的。这时想通过这条线(建筑物外立面外墙线)创建展开立面现有revit无法实现。
wr.marshall
It is recommended that Revit can extend the curve to generate an unfolded facade.
At some point a designer wishes to express design intent by creating an expanded elevation view of a complex form. For example, from A to B is composed of straight lines, circular curves, spline curves and transition curves. At this time, I want to create an expanded facade through this line (the exterior wall line of the building's facade), which cannot be achieved in existing Revit.
@aizaiwutuobang 看到这个想法 (See this idea): https://forums.autodesk.com/t5/revit-ideas/flattened-curved-elevations-sections/idi-p/6255768
@kimberly_fuhrman-jones please combine with https://forums.autodesk.com/t5/revit-ideas/flattened-curved-elevations-sections/idi-p/6255768
isabel_sotoNT7EE
Community Visitor
Is it already possible to do it in recent revit versions? It'll be also a great improvement for architectural design. Thanks!
conceptaicars
Community Visitor
Hello, greetings to all, I recently came across a solution that worked for me, and that was to install the environment
plug in and use Approximate Wall Path tool.
Enviar idea
