cancelar
Mostrando los resultados de
Quiere decir:
Fix transparency print problem
It is bad enough that you need to use the rasterized mode when printing transparencies generated by filters or general overrides.
I just realized that this approach does not work at all if the printed view is in wireframe mode. Surely this is not intentional, especially since the transparent element appear correctly on screen.
1 Comentario
MichaelWolff
Btw. I stumbled upon this in Revit 2019.2.6 and cannot currently be bothered to test grounds in a more recent version. I tried PDF24 and eDocPrintPro as PDF-printers and always ended up with vectorized output with no transparency.
Enviar idea
