Fix Stair Tread/Riser Numbers on multistory and sketch base stairs.
When numbering a multistory stair on section only the numbers in first stair are tagged, all the stairs on above stories keep without number tags. I think it's a revit error that must be addressed.
Another thing with stair numbering is that they don't work on sketch stairs. I don't know why, because in their property Revit show the numbers treads you have, and the majority of sketched stairs have their runs properly drawn.
Maybe stair with double run, Y or fork shape are awkward to numbering their tread, but you can maintain the same number for treads with the same heights.
6 Comments
samuelsanf
I see this is Fixed in Revit 2018, please mark as Implemented or archived.
@sasha.crotty @harlan_brumm
harlan_brumm
I'm please that as requested, we are marking this as implemented.  This is due to the new functionality in Revit 2018 that addresses this problem.  Thanks for voting and contributing!
The Factory
How can you make the numbering continue all the way through the levels, and not begin the count on each stair run indevidually...?
samuelsanf
@Anonymous, Thisi It is not possible for now. Hope this be addressed in the future.
Tarek_K
Status changed to: Gathering Support
Tarek_K
