See video for explanation:
https://appriver3651010148-my.sharepoint.com/personal/sjmanzella_hawainc_com/_layouts/15/stream.aspx...
The issue:
If all links are loaded in both models, the POWR devices from the ELEC.rvt model do not show in Floor Plan views in the ARCH.rvt; they do show in 3D and elevations.
If we unload the ARCH.rvt model from the ELEC.rvt model, then reload the ELEC.rvt link in the ARCH.rvt model, then the devices all show in the Floor Plan views.
The test was done in a default Revit 2022 Construction template, then we used the Wall Type and Power Device types from our active models. The issues is present in either type of templates, again, wanted to have the most stripped-down version showing this issue for this test to keep files small and example straight to the point.
We've exhausted our testing; I've also done test upgrades to Revit 2024 and Revit 2025 and the issues still exists. This issue is 100% related to Curved Walls only.
Linking by view does not work. Only solutions thujs far are to not used hosted devices or to host to workplanes. This is an 840,000 sq/ft building, 1000+ rooms, current proposed solutions are not workable.
I have submitted this to various support channels, last support's advice was to post here for additional help.
Thank you.
