Fittings Change to Default too Easily
This is particularly annoying with Duct Fittings. You set parameters on a duct fitting to be a certain way (let's say it length for example) and then make a change to the duct it is attached to and it reverts back to its default values (or changes the fitting altogether to the wrong one). It's very tricky to get it not to do that.
Rail Community
