Showing results forĀ
ShowĀ Ā onlyĀ
Search instead forĀ
Did you mean:Ā
Fire Rating is a "Type" Parameter on the structural beam, this is not fit for purpose as the same beam type can have a different fire rating, therefore it needs to be an "Instance" parameter, also this needs to be added to the structural columns
There is a need for both instance and type parameters on all components when it comes to fire rating. One parameter should specify the fire rating that the building part can resist, and another should define the fire rating demands.
