We are currently migrating data within this board to improve the community. During this process, posting, replying, editing and other features are temporarily disabled. We sincerely apologize for any inconvenience caused and appreciate your understanding. Thank you for your patience and support.
Filled regions Graphics Tab in properties
When creating a Filled region make the graphics tile visible.
can see it when looking at the Project Browser make it visible when i  create a filled region as well.
for clarification see pictures
Filled region Project BrowserFilled region Project Browser
Filled Region When Creating filled regionFilled Region When Creating filled region
3 Comments
A color swatch in the icon part of the Properties pallet for a filled region type with it's corresponding pattern/color would be greatly appreciated. Listing RGB-numbers just aren't very enlightening.
Tags (2)
elmorei
I believe those are "type" parameters as opposed to "instance" parameters.
Also, which version are you using?  When creating a filled region, the only parameters I get are:
stefan_gokstorp
im using revit 2021 thats the point of the post you can see the graphics (which indeed is a type parameter) when you select the filled region family in the project browser but when creating filled region it is under type properties would be helpful to see which color and pattern it has before putting it on the drawing,
not be able to change it mind you but to be able to see what graphic it has.
