Show only
Search instead for
Basically any information pertaining to the project as a document. AutoDesk seems to have forgotten that more information is involved in BIM than simply information about the building. The client/contractor wants information about who drew the model, who is building it, etc. I think that project recipients, material/construction specs and contract items should be parameters too, that way the entire project can be documented in one place...
@dplumb_BWBR This. The location of the local file is completely redundant in a title block, we need the actual path to the central file, that's where everything originates from so I've no idea why this isn't an accessible parameter in a label.
If i like to add the filename on my sheets i have the possibility to make this manuel by a costum parameter or by using the existing paramter "filepath".
To prevent errors the existing parameter is a great thing. but if the file is stored in a deep filestructure the filepath explode and overflows my sheet.
So I suggest to implement a systemparameter which shows only the filename and not the whole path.
A built in parameter for getting the file name of the Revit file without the path and a choice to include the file extension or not. Like the fields in AutoCad.
