Families - Lights on sloped ceilings
The Illuminating Engineering Society (IES) BIM Standards committee recently created a list of Autodesk Revit enhancement and feature requests based on a membership survey. We have shared a prioritized list with Autodesk and are posting them here, on Revit Ideas, to build community support to benefit the lighting design industry.
Please consider upvoting this Revit Idea.
Description:
In the real world, lights are often mounted to surfaces that are angled. Revit has a hard time doing that. For example, support wires for pendant fixtures are typically perpendicular to the floor. Also, the symbols (e.g., Symbolic Lines) need to show up properly in 2D.
5 Comments
Jason_Peckovitch
Not ideal, but I have made an adaptive Generic Model base with a nested pendant light in it that adjusts to slope of roof or ceiling, has a perpendicular support and shows correctly in plane. Caveat is that its a generic model and does not get inserted as a family but does show up in schedule and can be circuited.
Lighting Fixtures that adjust automatically would be the best solution. Thanks for putting this out there.
dan.stine
Thanks @Jason_Peckovitch ! Just one thought might be a reference plane toggle to stay aligned with the ground plane.
Jason_Peckovitch
@dan.stine I would lean towards adaptive but categorized as Lighting Fixture but that may be viable as well.
Set the family to Always Vertical.
Joey_JM
Yes please! I can see the benefit of adding an option to force the visibility of 2d symbols for many families/categories (not just lighting) that are hosted to inclined faces/workplanes.
Good point @ToanDN but there are cases where it isn't desirable to set a family to Always Vertical.
