Extend Section lines in plan even when pinned without affecting section view
It would be great if we could extend a section line in, say, plan view even when the section line is pinned, without affecting the actual section view
One of the saddest things that can happen in revit, is losing your sections, to colleagues unwittingly deleting, flipping or moving the section lines.
One solution is to pin the section line, to avoid non-deliberate changes. The problem is when the section lines are pinned, then you can’t control the 2d aspects of the section line, such as extending the section line in individual views. To do this, you 1st have to unpin, extend, and then re-pin.
As mentioned above, it would be great if while the section line is pinned, it can still be extended depending on the view, without affecting the section view itself.
Autodesk Customer Advisory Groups
