Show only
Search instead for
In case I'm doing something wrong coding here is the code snippet that I'm using for the pdf export.
using (Transaction t = new Transaction(doc, "Mario Tools: Export Sheets to PDF"))
// start the transaction
t.Start();
// create DWG export options
PDFExportOptions exportOptions = new PDFExportOptions();
//gets size from title block
exportOptions.PaperFormat = ExportPaperFormat.Default;
exportOptions.ColorDepth = ColorDepthType.Color;
exportOptions.Combine = thisForm.checkBoxCombine.Checked;
exportOptions.FileName = fileName; //only works if Combine is True
exportOptions.ExportQuality = PDFExportQualityType.DPI600;
exportOptions.HideCropBoundaries = true;
exportOptions.HideReferencePlane = true;
exportOptions.HideScopeBoxes = true;
exportOptions.HideUnreferencedViewTags = true;
exportOptions.MaskCoincidentLines = true;
//Don't think of this as a "continue" but rather as a silent mode
exportOptions.StopOnError = true;
////Make sure to not use these settings as they don't work if 'Default' size is used above
//exportOptions.PaperPlacement = PaperPlacementType.LowerLeft;
//exportOptions.ZoomType = ZoomType.Zoom;
//exportOptions.ZoomPercentage = 100;
exportOptions.ViewLinksInBlue = false;
//Get all sheets to export
// create a list to hold the sheets
List<ElementId> sheetsToExportIds = (from View eachview in selectedViewSet.Views select eachview.Id).ToList();
// export
try
doc.Export(path, sheetsToExportIds, exportOptions);
summary += "- OK: Files exported correctly to <" + path+ ">." + Environment.NewLine;
catch (FileAccessException e)
summary += "- FAIL: The File already exists/The File is already open/No ovewrite option is available in th API for now." + Environment.NewLine;
summary += "- FAIL: Exception: " + e.Message + Environment.NewLine;
summary += "- FAIL: Exception: " + e.StackTrace + Environment.NewLine;
catch (Exception e)
summary += "- FAIL: Failed at Export Command" + Environment.NewLine + Environment.NewLine;
t.Commit();
@a.bejenaru , we're going to leave this one as a new feature request, but know that it is being looked at as a possible bug. I will let you know if anything changes!
Yes, it could also be because the files is in use, which I would presume is why the API method does not attempt to overwrite, but provides the exception.
