Exclusive Item Numbers for Fabrication Parts
Hi all,
Currently when numbering Revit Fabrication Parts (specifically MEP Fabrication Ductwork) using the Item Number parameter the user does not receive a warning when a duplicate value is entered, as is the case for the Mark parameter. I simply suggest that users receive such a warning when entering Item Numbers on Fabrication Parts.
Note: To those also experiencing this issue, the attached basic Dynamo script will force the Item Number to equal the Mark. This allows you to use the Mark parameter for input (which warns of duplicates) and apply the same value to the Item Number parameter.
2 Comments
sasha.crotty
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
sasha.crotty
Status changed to: Archived
Forma Design Contest
Technology Administrators
