The ability to duplicate with sheet detailing is a great feature, but it also copies clouds/tags from issued revisions. If I'm duplicating the sheet with detailing only, it is a new sheet, and shouldn't include any data from issued revisions. To remove the issued revision from the sheet the revision dialog must be opened, the clouds/tags turned on, the revision un-issued, then the revisions on the new sheet deleted, and then the settings reset in the revision dialog.
Clouds and tags from issued revisions should be excluded from being copied when a sheet is copied. I would extend this to include excluding ANY elements that are hidden in the sheet view being copied, since lines and other annotations can also be hidden.
