cancelar
Mostrando los resultados de
Quiere decir:
Exclude revision clouds from issued revisions when Duplicating with sheet detailing
The ability to duplicate with sheet detailing is a great feature, but it also copies clouds/tags from issued revisions.  If I'm duplicating the sheet with detailing only, it is a new sheet, and shouldn't include any data from issued revisions.  To remove the issued revision from the sheet the revision dialog must be opened, the clouds/tags turned on, the revision un-issued, then the revisions on the new  sheet deleted, and then the settings reset in the revision dialog.
Clouds and tags from issued revisions should be excluded from being copied when a sheet is copied.  I would extend this to include excluding ANY elements that are hidden in the sheet view being copied, since lines and other annotations can also be hidden.
4 Comentarios
Excelente ideia! obrigado pelo envio @jkidder
@jkidder obrigado pelo envio da sua ideia
jkidder
This duplicated Duplicate views without revision clouds - they should probably be merged.
KentBurns
This is correct, but I don't think this is an idea, it's a bug that needs fixing. If you're duplicating a sheet that has revisions, the new sheet has never been issued, so shouldn't be uprev'd at all.
Enviar idea
