Entering nothing should revert to zero if appropriate
When you click into a decimal value parameter and accidentally end up at its right end, erasing everything (by back spacing), should leave with a zero value instead of asking the user to enter a zero. An empty slot should be a zero value unless there is some "has not been entered yet" state in which case it should be that.
