cancelar
Mostrando los resultados de
Quiere decir:
Enhance element ID functions
Element ID's can be useful for locating elements in the model.  However, they are cumbersome to use,  Suggestion is to show the element IDs in the instance properties of the element.  This could be a new category in the instance properties, such as 'More' or 'Advanced'.  This section might even include warnings that the element is generating.
29 Comentarios
No aplicable
yes, its very usefull
Nurlan-A.
This will save us from having to add a parameter and run the dynamo.
dplumb_BWBR
And, for #$@# sake, let us Copy and Paste the Element IDs!
Especially from the Warnings dialog
@Joey_JM  Thank you for the suggestions! I will look through them and combine the most similar.
The elementId property is really usefull to distinguish individual elements, but as it is right now this property can only be accessed through the API. It would be really usefull to be able to see the elementId in the elements properties browser in Revit, so that it's easier for the user who doesn't wish to use Dynamo or the API to pinpoint and keep track of individual elements.
Many thanks in advance!
Kind regards,
Jeroen van Halderen
Etiquetas (1)
Hi, @jeroen.van.halderen ,
Here is a similar Idea: Enhance element ID functions - Autodesk Community. I would be happy to merge your Idea with this one for you!
Thank you for your submission!
Kimberly
@kimberly_fuhrman-jones that's okay, I'll be happy to be merged with the other post you mentioned.
emodderman
I would LOVE to be able to schedule an element ID. SO frequently I have a huge list of ID's and for some reason, select by ID doesn't actually select anything and I can't figure out why. it clearly corresponds to an element in my model, but i can't get access to the data.
Enviar idea
