Enable the export of PDF´s with layers
Although there is the workaround of exporting sheets to dwg and then produce the layered pdf´s this workflow often results in a loss of graphic performance of the drawings. As it is an obligation for some building permits a direct export from Autodesk Revit would benefit the quality of drawings delivered.
3 Comments
BSzilagyi
Layer support for PDF would be a great advancement. However we can export PDF with proper file naming, the lack of PDF layers is a huge limitation to fulfill industry standards.
[The same DWG layer structure support also be used at IFC would be perfect for this feature too.]
Jenny-Rehbein
Community Visitor
das ist ein Muss! Sollte unbedingt ergänzt werden!
Jenny-Rehbein
Community Visitor
Das ist ein Muss! Sollte unbedingt in Revit ergänzt werden!
