Elumtools bug Analysis Display Style
Hi!
I am finding problems with the display of the analysis results from Elumtools. The Tech. support told me that it could be a bug in Revit.
The thing is, I am trying to set a fixed scale of values for the Lux levels, not dependant from min and max values, in order to compare properly different scenes and rooms.
The result though is as you can appreciate on the pics, while in the default style the results are showing the values, the one i customized only shows a minimun colour.
Can you please help me with that?
P.S.: I attached the .rvt as well.
Regards!
Cristian
2 Comments
scott_dakin
Can you describe what it should be doing in more detail, I don't understand the problem.
I'm hoping to use Elumtools, eventually, so it would be nice if any issues were fixed.
MattKincaid
This issue has been addressed as of the latest version of ElumTools.  Please download from the link below and install.
www.LightingAnalysts.com/DownloadElumTools
Forma Design Contest
