La sugerencia automática le ayuda a obtener, de forma rápida, resultados precisos de su búsqueda al sugerirle posibles coincidencias mientras escribe.
Mostrando los resultados de
Mostrar solo
Buscar en lugar de
Quiere decir:
Esta página se tradujo para tu conveniencia mediante un servicio de traducción automática. No es una traducción oficial, y puede contener errores o traducciones imprecisas. Autodesk no garantiza, ni expresa ni implícitamente, la precisión, la confiabilidad ni la exhaustividad de la información traducida por el servicio de traducción automática y no será responsable por los daños o las pérdidas que se produzcan como consecuencia de la confianza depositada en dicho servicio.Traducir
Please provide a method to change the size/angle of the default homerun arrow for Revit. We receive complaints from Contractors that the homerun arrows are difficult to see on printed drawings.
Here's my feedback around this topic: Provide a global option in Electrical Wire Settings for the home run arrows (custom annotation family, similar to tick marks). Perhaps could be added as a wire-type setting, just like for leaders of text, tags, etc. When wiring circuits together, Revit displays additional arrows and it seems a lot would prefer to have control over the graphics to not display the more than one arrow and let the circuit tag give you the circuit numbers.
ahillard, and others that voded on this, in Manage > Settings > Additional Settings > Arrowheads, if you create a type that uses the Arrow Style = Arrow, do the settings there provide you with the graphical control to achieve the desired arrowhead result? Or, is there some additional control that you'd require to achieve the desired arrowhead graphics?
martin, thanks for your suggestion, but to my knowledge, the Arrowhead settings have no impact on the graphics for the wire arrowheads. Wires automatically display an arrowhead when connected to a powered electrical device with a connector. To the extend of my knowledge, the wire arrowhead "homerun" size, angle, shape, etc., cannot be changed. I'm asking for a method or settings to change it.
Hi ahilliard-- sorry for the confusion. I understand that these settings don't presently modify the homerun arrow... however, if they did, do they provide you the graphical control over the arrow that you would need? In otherwords, instead of inventing a new UI and method of defining an arrowhead shape for a homerun arrow, does what is here fit the bill to provide the graphical manipulation you'd need?
I think the current graphical control for creating an arrowhead will suffice for creating a homerun arrowhead. We'd like to have more control of when the arrowheads are shown and how they are shown. For instance, when creating a multi-circuit homerun it shows two arrowheads, it would be nice to have an option to "Only show one arrowhead for Multi-circuited home runs". Similar to the way we have options for the tick marks.
Also, it would be nice to be able to group circuits together maybe in the panel schedule that are circuited together. Currently wires must be created to connect circuits together and for the Homerun arrow to report the multiple homeruns with a tag.
As you mentioned "We'd like to have more control of when the arrowheads are shown and how they are shown. For instance, when creating a multi-circuit home run it shows two arrowheads, it would be nice to have an option to "Only show one arrowhead for Multi-circuited home runs".
Do you mean you would like to show one arrow in all multi-home run circuits but then tag the wire with circuit numbers? Does the behavior in following image meet your expectation? Thank you!
hi David-- indeed, it is a separate issue (e.g., each is independently addressable)...the benefit of separating them on the Ideas site here (which I should have articulated back then) is that other issues buried in the thread may only be valuable to a small portion of the users that find the original request valuable (or, the 'tack-on' request may actually be more important than the original)... having those independently voted helps with getting the data to support the changes. Having them separated out may also help show a trend in a particular area for example, if x out of the top y number of items were all related to the same general area, and thus, perhaps of different value to tackle the issue more broadly, vs. a point solution.
In any case, the feedback is helpful, and thanks for coming back, no matter how many different accounts you wish to use ;).
Haha thanks Martin, too many Autodesk Accounts over here If you think I should open this as a separate wish, then I can do that. Since this wish was specifically dealing with graphics of home runs, I felt like it was appropriate to expand on the topic in the hope that both issues could be handled as part of one "fix" since they are so closely related. I don't recall seeing a specific wish dealing with my specific feedback at the time, but I'll do a search before starting a new one and vote instead if one does exist.
Martin if you still are monitoring this thread, I think there should be a parameter for the number of heads that will be required and yes a style for each. My vote 1+.
@Anonymous & @jaboone - i would recommend that you create separate idea threads for these additional requests... so that the community can vote on the need of these and we can gauge relative to other items. Further, since the original idea at the top of this thread is already accepted and available for preview in beta, this thread will be closed when that functionality is released.
