I should be able to copy an entire panel+loads between projects. If I'm working multiple projects within the same building that draw from the same distribution panels, why do I have to re-create the panels in each subsequent project? Revit should be able to package the panel with all its data and loads and export to another project. They don't need to be linked, just brought into the new project as "existing" and then I add whatever new loads.
