Please make the homeruns for circuiting more editable, especially when combining multiple circuits in one home-run. It clutters the drawings to have homeruns with two and three arrowheads. Parameters for the amount of arrowheads that is desired would be great. An instance parameter is preferred. That way one arrowhead can be shown for the actual homerun that is being tagged with the panel and circuit description, and then 0 arrowheads can be selected for the homerun wire between two devices of different circuit numbers. The arrowheads are not necessary on these, if it should be designated between devices, the tick marks are sufficient.
