La sugerencia automática le ayuda a obtener, de forma rápida, resultados precisos de su búsqueda al sugerirle posibles coincidencias mientras escribe.
Mostrando los resultados de
Mostrar solo
Buscar en lugar de
Quiere decir:
Esta página se tradujo para tu conveniencia mediante un servicio de traducción automática. No es una traducción oficial, y puede contener errores o traducciones imprecisas. Autodesk no garantiza, ni expresa ni implícitamente, la precisión, la confiabilidad ni la exhaustividad de la información traducida por el servicio de traducción automática y no será responsable por los daños o las pérdidas que se produzcan como consecuencia de la confianza depositada en dicho servicio.Traducir
Can you make walls floors and roof editable, I. E the system families. It's real restricted as of current. If not can you add in more forms of wall build ups like cross laminate, stud wall, shingle cladding, corrugated steel cladding, etc...
Maybe I misunderstand your request but you can achieve pretty much any build up by editing the appropriate system family. Simply duplicate and then edit the layers assigning desired depths/thicknesses and materials.
Im not long at revit, but what I ment was that you can't generate a wall buildup detail nessaseraly to the way you want. The reason being; each layer in your wall systems family can only be then edited as a single volume. In my circumstances I would be thinking of an external wall build up as; a stood wall with insulation in between and then cladded externally with timber shingles. So for the reason that I can't create a wall family where I can build in individual elements that can have parameters quantities, etc... attached. I. E centre to centre studs, insulation in-between, etc... I think editable system families should be added to revit. I. E of current if I have a battoned wall the best I can do is have a solid timber wall layer show in my detail.
I haven't been doing it long, but if you have a solution to this please let me know.
