Edit Schedule Directly on Sheet
Would love the ability to "double-click" into a schedule on a sheet to edit it, just like any other view.
It would help with the following:
- Show a live view of graphical changes, such as borders, fonts, bold, etc.
- Help eliminate the back-and-forth we have to do to see what our changes look like between the schedule view and the sheet.
- Show the full text area when using "Shift+Enter" to add extra lines within rows (which we use a lot).
This feature should also include the ability to "select" (single-click) a schedule, and get the "Fields", "Filter", "Sorting/Grouping", etc. options while on the sheet view.
Thanks!
14 Comments
Yes! Yes! Yes!
sasha.crotty
Thanks for your submission and votes on this idea!  We are evaluating where this request falls into our roadmap and will provide an update when we have made a decision.
The Factory
damjanuzelac
This feature is long overdue! It's a must - as soon as possible.
Even better, the schedule view itself should be WYSIWYG.
Thank you
NateBrush
Please expedite this! Formatting text in schedules is one of the largest issues we have. Making the schedule editor WYSIWYG or making schedules editable on sheet would make it much, much easier to handle multi-line text.
Great idea!!!!
Also default font in schedule editing is much too small. As others noted it should be possible to edit schedule on the sheet in wysiwyg
pieter1
I agree with @damjanuzelac that it would be even better if the schedule view itself was WYSIWYG. It would also take care of this request: Schedules support multi-line input
Status changed to: Gathering Support
We are updating this thread to Gathering Support. We are continuing to evaluate where this request falls into our roadmap and will provide an update when we have made a decision.
The Factory
bjornrubin
This would be a welcome update. While it is necessary to "open" the schedule when setting it up, it would make for a smoother workflow if tweaks and changes to filters etc. could be done directly on the sheet.
alexanderEO
Bump
sclaytonYP63S
Honestly cannot believe this has still not been implemented. What a pain to try to edit text that goes beyond one line or the width of the schedule. Why the sheet appearance and schedule appearance do not correspond makes no sense and adds much inconvenience. Schedules should also have an 'apply' button instead of just 'ok', less time spent opening and closing fields, sorting, etc. dialogues just to see applied changes.
idraft_designs
Really would be good
ks2_wmb
TBH the schedule editing screen is still a bit clunky.  I would rather have the schedule editing screen be streamlined instead (why are column widths tied together between the two views even though they don't use the same font size?).
rbaillet
9 Years ago, the response to this was
"Thanks for your submission and votes on this idea!  We are evaluating where this request falls into our roadmap and will provide an update when we have made a decision."
Are you done evaluating this request? Or do you need another nine years to determine if it should be placed on the roadmap?
Autodesk needs to actually do something here. The way schedules handle text hasn't changed since Revit 1.0.  If you look at screenshots from 1999 (TWENTY-SIX YEARS AGO) the schedules look exactly the same. It's long overdue for a graphics overhaul.
