Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Edit in-place Revit links
As we are doing lots of model referencing and linking, it would be more efficient if Revit has the capability to "edit model links in-place". This means that we do not need to open the linked files separately to do the adjustments needed and the linked files can be edited directly to the currently opened working file.
37 Comments
Hi Autodesk,
My dream would be able to inplace edit linked files in Revit, similar to the function we have with CAD xref's.
This would save links being dropped when we open in the same Revit environment, and reduce the amount of circular references to keep everything coordinated.
I am sure others would love this function.
Now this is a long shot...
We often need to have 2 or 3 linked models and it would save considerable amounts of time if these could be edited from within each other (much like the group editor).
Lots are going to ask why so this is why:
We are medium size FF&E contractors, our work consists of both fixed and loose furniture, when working on a project we are often provided with 2 models, the building and the M & E models which we link into our projects.
We create pdf & DWG layouts of the rooms we are working in and we also often supply our furniture model to the main contractor & Architect for visual and renders etc and also to the other subcontractors for clash detection etc.
The architect/main contractor want everything (fixed and loose furniture) but the subcontractors only want the fixed (as the loose simply clutters up their model).
We have no use for a central model as we currently only have a single person at any one time working on it and that is an entirely unnecessary complication, in addition worksets would only solve part of the issue.
To achieve what we want we create 3 models, a fixed furniture model, a loose furniture model and a drawing sheet model, this means we can use them as follows:
Fixed model - can be issued to the other subcontractors very quickly without having to delete all the views, 3D views, schedules and drawings
Loose model - as above can be issued with the above to the Main contractor/Architect for display to the client
Drawing Sheet model - contains sometimes hundreds of views, sheets, schedules etc that we can use to issue our drawings from
If anyone can suggest a better workflow I would love to hear it.
Similar to editing a group but with RVT links versus opening a separate session of Revit and having to Syncronize and upload
Tags (1)
i need to be able to edit my links inside the file like edit xref in autocad using the refedit command and also send notification to the team link done in autocad
It would be great if we have an option that give us the opportunity to edit the links files in the project that we have linked them. It would be Like the icon we have in AutoCad "edit block in place".
pedro
Even being able to just have the linked model open in the same instance of revit would be helpful. Why must it be unloaded to open it? Currently I run two or more instances of REVIT to be able to switch between the linked models and the main model.
Yeap totally agree! Sometimes even that doesn't work, cause Revit won't reload the reference link as it 'thinks' Revit has it open. Very annoying.
Does anyone know if this has been addressed in 2019?
I definitely agree with this idea. Especially in CCSM & MEP which have a lot of link models.
rommel_bernal
Yes, for CCSM (Coordinated Combined Services Model) which is consist of 13 different systems model + ARC model + STR model, it will definitely boost productivity. Just imagine if you will be able to edit the linked model in the current model host where there are clashes as visually inspected, then the coordination would be much more smooth and instant.
I completely agree with this idea for more efficient coordination and production.
yes, I agreed also
its repeated a lot of times but Autodesk not paying attention to this valuable request
I hope the do this time
GA-LT
it would be great!! but binding links without any problems and 10.000 warnings, deleted objects etc would be fine too! generally to bind rvt links is not possible now so it's useless. therefore more control and quick access to linked models will be very helpful
rommel_bernal
Yes, we are also avoid binding links in our workflow as you had experienced. Another case also is one of our colleague binded 2 model versions of ACMV + Electrical and exploded both (old and new versions) and the next week we found out about the problem and we had a hard time in cleaning-up the host model to remove the older model.
pascal.robben
what about company / aspectmodel rights when edit in place is an option?
If this would be a future option, edit in place should be able to lock models from editing when you are not the owner.
rommel_bernal
That's a good idea Robben, a lock from the model author preventing other stakeholders to edit the model.
pieter1
rommel_bernal
Yes agree, never thought there is an earlier post with same requested feature.
RobertAGlover
This is made more useful because you can't open a host model and a linked model in the same copy of Revit. I think they will need to get past that code bug before they can incorporate this idea. But I really really hope they can do it!
pascal.robben
in BIM 360 it is possible to open host and linked models in the same copy of Revit
jdelaney_kearch
We desperately need a tool that allows us to repeat apartment units.
Model groups, assemblies, and traditional links just don't cut it. Whether it is a new tool or in-place link editing doesn't really matter to me.
Desired functionality:
Copy one or multiple unit instances unit between levels
Changes in one unit propagate to all units of the same type
All editing happens in the same copy of Revit
Tag and schedule the entire unit
Control the visibility of the entire unit without having set up elaborate filters or create new types (this is why it is extremely difficult to work with groups)
Automatic disallow join to walls outside of the unit
