Edit current scope box
In order to use scope boxes (and make the modellers use them) they should be at least as editable as view crop regions. Right now all scope boxes can be edited in a view except the one that is applied to it.
8 Comments
franciscusmG6FJ7
Possibility to draw and modify accurately scope boxes the same way you can do with crop regions.
franciscusmG6FJ7
even convert a crop region to scope box, the same way it's possible to convert view properties to view template.
Nick.Curtis
Agree, this would include a component or mass like interface to create scope boxes of irregular shape, ie using Boolean operations or pick geometry.
GHASEM_ARIYANI
Hello Autodesk Revit Team
When we create a 3D view based on the Scope box in a 3D view, we can,t change the size in the scope box 3d section.
I think if this feature is added, the speed will increase And also becomes more user-friendly. (as such 3D view without use Scope box  or plan )
Erwin_Feitsma
Is it possible to make a skope box that is editable by size ? (like crop regions)
with kind regards
scbunker
Hi @Erwin_Feitsma, you're posting to the wrong forum. This is the forum for feature requests. I suggest you go post in the other Revit forums.
Curty102
@MichaelWolff  Wouldn't disagree.  And since you seem like a modeler, have a look at this idea too:
Scope Box Origin and XYZ Axies
Cheers
jschwab_fsb-ae_com
When creating "Scope Boxes", it would be very helpful if the user had the "sketch lines" as with match lines and view cropping.
Rail Community
