Edit and Create Tags in Place
Sometimes the need for a quick tag to label things in a drawing is really useful but currently it’s not quick or easy to create a completely new tag family or heavily edit an existing tag.
It would be great to be able to create a new tag in the drawing or sheet that you’re currently working in similar to how we can create a family in place, that doesn’t require opening the tag family file itself or or having to jump back a forth making tweaks to tags.  Perhaps it would have to be separate from the more rigid tags that are more standardized across a company. I’m sure that could be worked out.
In a similar way it be great to be able to edit a tag within the view so that you can adjust the text size are fine tune the spacing between different labels in the tag directly within the view you’re working in and save that edited tag within the model without having to open a completely separate family file.
